# Custom Avatars
**URL:** https://meta.discourse.org/t/custom-avatars/374943
**Category:** Support
**Created:** [July 20, 2025, 11:54am UTC](https://meta.discourse.org/t/custom-avatars/374943 "2025-07-20T11:54:30Z")
**Posts on this page:** 8
**Page:** 1
<div class="post-metadata">
### Author: ![Timelord](https://avatars.discourse-cdn.com/v4/letter/t/ba9def/32.png) [@Timelord](https://meta.discourse.org/u/Timelord)
#### Post date: [July 20, 2025, 11:54am UTC](https://meta.discourse.org/t/custom-avatars/374943/1 "2025-07-20T11:54:30Z")
</div>
I may be missing something super obvious, but, where/how can I _upload_ custom avatars that will be assigned to my users on signup.
I see admin/config/files allows us to link to a URL, but how do I upload them to MY server for selection?
### Author: ![merefield](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/merefield/32/176214_2.png) [@merefield](https://meta.discourse.org/u/merefield)
#### Post date: [July 20, 2025, 12:01pm UTC](https://meta.discourse.org/t/custom-avatars/374943/2 "2025-07-20T12:01:06Z")
</div>
`Selectable avatars` in site settings? (and associated settings).
See the `Files` section for complete list.
#### Post date: [July 20, 2025, 12:03pm UTC](https://meta.discourse.org/t/custom-avatars/374943/3 "2025-07-20T12:03:12Z")
</div>
Thanks - I thought this might be it, but it does not say it will be autoassigned.
I want to be sure an avatar other than the default letter is automatically assigned.
#### Post date: [July 20, 2025, 12:04pm UTC](https://meta.discourse.org/t/custom-avatars/374943/4 "2025-07-20T12:04:35Z")
</div>
Good point, ~~I’m not aware of that function, perhaps others will chime in, but you may have to build a plugin to achieve that (in which case consider #Marketplace)~~
FYI the topic is here:
> [@Selectable avatars](https://meta.discourse.org/t/selectable-avatars/92656):
> Avatars are a big part of anyone’s online identity. Discourse already supports 3 options when it comes to avatars: based on the first letter of your username, your Gravatar or any images you want to upload. But what if you want to provide your users with a limited set of avatars to choose from? It’s now possible thanks to the “selectable avatars” feature! As an admin, if you click Edit next to the selectable avatars site setting, a modal will pop up and ask you to start uploading ava…
#### Post date: [July 20, 2025, 12:06pm UTC](https://meta.discourse.org/t/custom-avatars/374943/5 "2025-07-20T12:06:35Z")
</div>
Thanks,
I guess a simple workaround would be to use something like [imgur.com](http://imgur.com) for the avatars, and add those URLs, however I ideally would like to have all images served from my infrastructure
#### Post date: [July 20, 2025, 12:06pm UTC](https://meta.discourse.org/t/custom-avatars/374943/6 "2025-07-20T12:06:46Z")
</div>
Oh wait, from that topic:
> [@Selectable avatars](https://meta.discourse.org/t/selectable-avatars/92656/1):
> Newly created user will automatically be affected a random avatar from the list.
#### Post date: [July 20, 2025, 12:08pm UTC](https://meta.discourse.org/t/custom-avatars/374943/7 "2025-07-20T12:08:06Z")
</div>
Just found it also!!!
### Author: ![system](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/system/32/443519_2.png) [@system](https://meta.discourse.org/u/system)
#### Post date: [August 19, 2025, 12:08pm UTC](https://meta.discourse.org/t/custom-avatars/374943/8 "2025-08-19T12:08:50Z")
</div>
