Custom Icons for Invite Friends
(Safa Faheem) #1
Hi there,
Right now, on our website, we have a little paper airplane for the Invite Friends feature on our site. The paper airplane does not really signal an “invite” for us, so I created a custom .ico file I’d like to use to replace that instead. Where would I go or what steps would I take in order to change the icon? I looked around in the Settings but could not find it for Invite Friends specifically.
Thank you,
Safa F.
(Jeff Atwood) #2
Where are you seeing a “little paper airplane” in Discourse? I am not aware of that glyph being used anywhere.
(Safa Faheem) #3
Hi Jeff,
Thanks for your response. It is on the top right-hand side. See the image below.
Safa
(cpradio) #4
That looks to be some sort of plugin you have installed. Default Discourse doesn’t have that…
(Mittineague) #5
Yes, that, and the speech balloon with the Notifications circle was a few versions ago at least.
(Safa Faheem) #6
Okay, I’ll check it out. Thanks!
