Custom JS in head makes messages not work
(Lars) #1
I’m on the latest update, and messages has stopped working. Clicking my avatar at the top right, then the messages icon no longer works. I guess this is why clicking a username and clicking the “Message” on the card does nothing as well.
I got reports from my users as well :slight_smile:
Is it just me that needs to rebuild or something?
EDIT: Going to a user profile, then clicking “Message” at the top works, oddly.
User profiles no longer showing up after latest update to to v1.9.0.beta2 +95
(Sam Saffron) #2
This works here, so its most likely a plugin.
Can you try in safe mode ?
(Lars) #3
It seemed to work in safe mode. The only third party thing I use (I think) is the Retort-plugin that allows people to react to posts…
Other than that, I don’t recall installing anything else…
(Sam Saffron) #4
Then that would be it :open_hands: raise it with @gdpelican on Retort - a reaction-style plugin for Discourse
(Lars) #5
I just tried disabling everything:
Still doesn’t work though :confused:
(Sam Saffron) #6
That does not necessarily mean it is disabled, try rebuilding without it.
(Lars) #7
OK, I’ll try that! :slight_smile:
(Lars) #8
I rebuilt the app without the retort-plugin (removed it from app.yml) - The issue persists… Any other ideas?
EDIT: Side note: Rebuild caused the server to become unresponsive for a long time, forcing me to power cycle it - the rebuild after that went quickly and the site is now up again…
(cpradio) #9
Do you have any themes that are utilizing JavaScript (and not purely CSS)?
(Lars) #10
@cpradio, that was it. I have some custom fields on the user card and profile. I removed it, and it seems to work now. What is wrong with it?
https://pastebin.com/eTNTqGCe
EDIT: I know it’s a mess, but it was working :stuck_out_tongue:
(cpradio) #11
When you have it enabled, what is the error message that appears in the Dev Console (press F12 in your browser)?
(Lars) #12
When I click the username to bring up the card, this shows:
The message button doesn’t work when the card shows…
(cpradio) #13
I’m fairly certain this is not related but the error message is definitely similar.
Or maybe it is. I’m not seeing anything at a first glance. If I have time, I’ll take a more thorough look later today.
(Sam Saffron) #14
That is a BIG file.
I would do a binary search to see what part of it causes the breakage.
  • Delete half, is it still broken?
  • Delete another half, is it still broken?
  • Etc…
Find the smallest possible repro of the problem.
