Custom message in flag report
(gauthier) #1
Hi,
When user report message with custom reason, where can I find the text which was entered?
Thanks
edit 10/10: moved to #bug, see here
Bug in TL0 message flagging
(Jay Pfaffman) #2
Click the title of the topic to navigate there?
(gauthier) #3
And then?
On the topic, i have this
I still don’t have the sentence which was entered by the user. :confused:
Thanks
(Jeff Atwood) #4
The text entered is in the PM topic created by the flag.
(gauthier) #5
Which PM? Between Who and who?
I’ve never received any PM after flagging a topic, neither in inbox, nor in sent :confounded:
(cpradio) #6
Moderators get it. It ends up in a Moderators inbox (which you can access, if you have moderator rights, on your Messages page)
(Da Beast 45) #7
Try clicking on the place it saids you notified moderators. It should take you the message.
(gauthier) #8
Do you talk about this?
I have nothing inside except some backup problems
Thanks, and sorry for the long time to answer…
Unfortunatly, not…
It’s not a link.
(cpradio) #9
No, that is the Administrator one, I’m 90% certain it is only in the Moderators inbox. Make sure your user also has Is Moderator enabled via the Admin > Users page (if you want to see it – I think)
(gauthier) #10
Thanks,
I have moderator role enabled, and i’m in the group moderator.
But I don’t see the moderator inbox, and none of the moderators either.
I’m sorry, but its really unclear for me.
(Da Beast 45) #11
It should be in your messages inbox.
(gauthier) #12
It should, but it’s not.
(Mittineague) #13
If it isn’t in the Inbox, maybe another member Archived it?
(cpradio) #14
Or maybe even deleted it (I think that is also possible)
#15
When a user flags a post for a custom reason, staff users will see the reason entered by the flagger directly on admin/flags below the flagged post without having to navigate to the PM created by the flag.
@gauthier is not seeing the custom reason as per his screenshot.
If a staff user deletes the PM created by the flag, I’m 90% certain the custom reason will not show up. Look in your staff logs or in the flagger’s deleted posts page.
(gauthier) #16
Ok, I’ve found the solution, but it’s very strange…
Maybe this topic should be moved to #bug ?
Let me explain
My forum AND my account is French.
When both are set to french, and i flag a topic, i’ve the case n°1 like below. No custom flag visible anywhere. No PM, no in flag page.
When I set Forum default language to english, and i keep my account to french, i had case n°2.
No custom message, but only the title of the topic and a button 'Visit the topic’
When forum and account are set to english then a topic is flagged, i had the case 3. Everything works perfectly. :confounded:
It’s strange no?
Am i Crazy?
Somebody can reproduce?
In the screen, ‘Test signalement 1’ and ‘Test signalement 2’ are missing, but ‘Test signalement 3’ is ok.
Since that, I have the Moderator Inbox. Moderators too.
Like you see in my previous message (here) I had only admin before.
(gauthier) #17
Nobody can reproduce?
(Da Beast 45) #18
I think the staff can.
