Custom styling doesn't apply to admin pages
(Adam Capriola) #1
I added this to my stylesheet:
.d-header {
    background: #333;
But it doesn’t apply on admin pages. (I’ve tried refreshing a lot but no dice.)
(Mittineague) #2
This might not be the same issue you’re having, but it might be.
I was playing with CSS on my localhost yesterday and noticed similar.
Even though I did “Save”, the style didn’t take
However, after I shut down the server and started it up again, then the CSS was in effect.
Maybe having an “Apply” would negate the need for a server restart?
(Ben T) #3
Designs (should be/are) disabled for admin pages, in case you break them. This topic might explain why the styles might not be appearing as well.
(Adam Capriola) #4
Ah, ok. That makes sense. It’s still annoying though when my transparent logo looks dashing against my dark background on the frontend, then is neutered on admin pages.
Frontend:
Backend:
(Kane York) #5
I think it would be safe to have color customizations show up in the admin screens, no?
Something to look forward to! :smile:
(Neil Lalonde) #6
Yeah that should be safe, unless you somehow chose colors that make everything invisible… Hmmm…
(Dan Porter) #7
I was about to report this, but glad I searched.
I felt it was a bug, but as @neil mentioned it’s intended behaviour.
It’s worth mentioning that you can still break your site by inserting broken CSS in the Content->HTML Head section of the admin panel. This applies even in the Admin section.
(Robin Berjon) #8
Could there perhaps be an “Apply to admin as well (DANGEROUS)” setting? Once you have a style enabled and you can tell that it’s not breaking the admin pages, it would be nice to be able to have some consistency.
(Régis Hanol) #9
Since we don’t support styling the /admin section, I just pushed a fix that will automagically disable custom stylesheets in the /admin section and enable them back when you’re leaving it :rose:
https://github.com/discourse/discourse/commit/7e1651a36e9d47f9a987b37481ef05057f8b497c
Inconsistent body class for /admin paths? (disabling top navigation)
(Régis Hanol) #10
