Customize subject format for standard emails
#21
Hi all,
Don’t know this is the correct place to ask this question. Can someone tell, what are the “standard emails” in Discourse. In the Admin / Settings / Email / email subject it says, “Customizable subject format for standard emails”.
Regards
(Jiamin Zhu) #22
I would also love to have bracket removed. Or if that’s not possible, if there another way to get category name?
(Tarek Loubani) #23
Hello friends,
I am trying to show only the subcategory, since I have unfortunately long descriptions for categories and subcategories. Several iphone users report the emails don’t show the actual topic due to this. I have reduced the community name to 3 letters, but not sure how to get only the subcategory. Any thoughts?
(Tarek Loubani) #24
By way of follow-up, I’ve found the line responsible, but can’t figure out how to properly access the “subcategory” variable:
This is line #68 in lib/email/message_builder.rb:
subject.gsub!("%{optional_cat}", @template_args[:show_category_in_subject] ? "[#{@template_args[:show_category_in_subject]}] " : '')
Obviously the variable includes both category and subcategory. Any ideas how I could blow these apart and only take the sub-category?
(Steve) #25
I was trying to only show the subcategory. On my site, the categories simply group the subcategories. On an email, category isn’t as important as subcategory.
(Tarek Loubani) #26
Any luck with this? I haven’t yet had any figuring out how to show only subcategories.
(Steve) #27
The only solution I found was to move the subcategories into categories. I also made the category names shorter.
(Alex Armstrong) #28
I’d also be interested in only having a field that showed: subcategory OR category. In other words, that would show the subcategory, if available, or the category otherwise.
(Peter N Lewis) #29
In the Admin settings, there is a field for “email prefix” - which says “The [label] used in the subject of emails. It will default to ‘title’ if not set.”. I have this set, and my “email subject” set to “%{optional_re}[%{site_name}] %{optional_pm}%{topic_title}” but the former is not used, the site title is used instead.
How does one use the “email prefix” in the subject? Or should I just repeat it explicitly?
(Peter N Lewis) #30
Actually, looking back, it appears this might be a regression in around June 2017. At least, that was the time the email subject changed to stop honouring the “email prefix” setting.
(Alex Armstrong) #31
I find it amusing when I search for how to do something on Meta and find that I’ve searched for it before (and failed to find a solution):
:smiley:
(Sam Saffron) split this topic #32
A post was split to a new topic: Allow adding tags as a custom format for emails
(Simon Cossar) split this topic #33
A post was merged into an existing topic: Email headers showing post ID #
