Customizing email footers
(Francois) #1
Hello,
I just installed an instance of discourse and I am trying to customize the email footer. Currently, all emails that are sent by my discourse instance have the following footer:
To unsubscribe from these emails, click here.
However, I would like to customize this text to be more explicit about what happens if you click on the given link. I found how to customize email templates from the admin page and I was able to add the text and the links that I wanted, but I haven’t found how to remove this default “unsubscibe” message. Do I have to edit the file server.LANG.yml? Or is there a way to remove or modify this default message directly from the admin page on the website?
Thanks!
Francois
(Felix Freiberger) #2
You can find this snippet in the Text Content section, also in the Customize section of the admin panel :slight_smile:
(Francois) #3
Thanks! That worked great. I did have to check the box Only show overridden to see the text I wanted to modify.
