Data Explorer Queries Results
Hey Folks!
We’ve got some queries that are pulling some stats for us from the last thirty days. Let’s say I just performed some action that should be counted in that stats but when I run the query it’s not reflected there. I need to wait some time in order to have it counted in the stats.
Can any of you guys told me how it looks like from the postgresql standpoint and the data explorer plugin or if it actually might be some issue in the query itself? Thanks for help!
Data Explorer queries the live database, so anything you did on the site should be reflected. Sharing the query here would be a good first troubleshooting step. To make it easier to read, please be sure to wrap it in a code block:
Query goes here
-- [params]
-- string :interval = 1 month
-- string :trunc = month
WITH timeperiod AS (
    SELECT date_trunc(:trunc, CURRENT_TIMESTAMP - INTERVAL :interval) as start,
    date_trunc(:trunc, CURRENT_TIMESTAMP) as end
postsread AS (
    SELECT user_id,
    count(1) AS visits,
    sum(posts_read) AS posts_read
    FROM user_visits, timeperiod WHERE posts_read > 0
    AND visited_at > timeperiod.start
    AND visited_at < timeperiod.end
    GROUP BY user_id
solutions AS (
    SELECT ua.user_id,
    count(1) AS solved_count
    FROM user_actions ua
    INNER JOIN timeperiod ON ua.created_at >= timeperiod.start
    AND ua.created_at <= timeperiod.end
    INNER JOIN users ON users.id = ua.user_id
    WHERE ua.action_type = 15
    AND users.admin = 'f'
    AND users.moderator = 'f'
    GROUP BY ua.user_id
likes AS (
    SELECT post_actions.user_id as given_by_user_id,
    posts.user_id as received_by_user_id
    FROM timeperiod, post_actions
    LEFT JOIN posts ON post_actions.post_id = posts.id
    WHERE post_actions.created_at > timeperiod.start
    AND post_actions.created_at < timeperiod.end
    AND post_action_type_id = 2
likesreceived AS (
    SELECT received_by_user_id AS user_id,
    count(1) AS likes_received
    FROM likes
    GROUP BY user_id
emails AS (
    SELECT email, user_id
    FROM user_emails ue WHERE ue.primary = true
replies AS (
    SELECT posts.user_id, count(posts.id) as replies
    FROM posts, timeperiod, postsread WHERE posts.post_type = 1
    AND posts.post_number > 1
    AND (posts.created_at > timeperiod.start
    AND posts.created_at < timeperiod.end)
    AND posts.user_id NOT IN ('-1', '-2')
    AND postsread.user_id = posts.user_id
    AND posts.topic_id NOT IN ('4','24','26','32','33','34','35','36','37','38','39','40')
    GROUP BY posts.user_id
in_group AS (
    SELECT gu.user_id
    FROM group_users gu
    JOIN groups g ON g.id = gu.group_id
    WHERE g.id = 41
not_in_group AS (
    SELECT users.id
    FROM users WHERE users.id IN (SELECT * FROM in_group)
SELECT postsread.user_id,
       name,
       email,
       COALESCE(solved_count,0) AS solutions_prov,
       COALESCE(likes_received,0) AS likes_recv,
       COALESCE(replies,0) AS replies_made,
            (COALESCE(solved_count,0) * 3) +
            (COALESCE(replies,0) * 2) +
            (COALESCE(likes_received,0) * 1)
       ) AS total_points
FROM postsread
LEFT JOIN solutions USING (user_id)
LEFT JOIN likesreceived USING (user_id)
LEFT JOIN emails USING (user_id)
LEFT JOIN users ON postsread.user_id = users.id
JOIN not_in_group ON not_in_group.id = users.id
LEFT JOIN replies ON replies.user_id = users.id
ORDER BY total_points DESC NULLS LAST```
:man_facepalming:
I forgot some key questions: What data are you looking to have this query provide, and what data (action you took) isn’t being reflected?
That’s basically a query for our leaderboard. We’re taking into account solutions provided, likes received and replies made. I have put this query together and then verified it’s results manually. Picked one guy and checked in his activity the number of replies made for example and it seems like the newest weren’t counted.
Hi Konrad,
I think the only problem is the JOIN between LEFT JOINs.
Let me know if this works for you.
Michelle
-- [params]
postsread AS (
    SELECT user_id,
    count(1) AS visits,
    GROUP BY user_id
solutions AS (
    SELECT ua.user_id,
    GROUP BY ua.user_id
likes AS (
likesreceived AS (
    FROM likes
    GROUP BY user_id
emails AS (
replies AS (
in_group AS (
    SELECT gu.user_id
    FROM group_users gu
    WHERE g.id = 41
not_in_group AS (
    SELECT users.id
       name,
       email,
       ) AS total_points
FROM postsread
LEFT JOIN (
    SELECT users.* FROM users
) AS users ON postsread.user_id = users.id
From my perspective it doesn’t do anything in terms of numbers. This one is for filtering only those people whose primary group isn’t our company employees group. So that basically picks only external users filtering out company employees
Konrad,
I understood and in the above adjustment I kept this filter, but to work I had to include it as a subquery in the LEFT JOIN, otherwise, the result of the query would always be empty.
Test and let me know if the result is what you expect. :wink:
Thanks Michelle for debugging it with me!
Unfortunately not. There are two cases here that seem to be problematic:
  • Right now this query displays all the users not only external ones but also our company employees etc
  • The results are still not valid for example for myself where I know how many replies and solutions I had yesterday in both fields it shows 0
Not sure what other knowledge to share to help us debug it.
