Database seems too big
(Jay Pfaffman) #1
I’ve got a site with 1.6M posts and 25K users. The database dump is about 8.7GB, which takes up 22GB of space in Postgres. I generally scoff at people whining about deleting this or that to save space in the database, but 22GB for 1.6M posts seems like a lot.
I upgraded to PG 10, dumped and restored the database, thinking that might help, but it didn’t. I think that this may have started on RDS before I moved it to Digital Ocean, if that provides some clue.
Does this seem normal? Is there some place I could look to see if there’s something bizarre in there?
(Rafael dos Santos Silva) #2
You can run the queries here to find if there is something strange: Disk Usage - PostgreSQL wiki
First thing to check is if there is another dangling schema from a backup (backup and restore schemas).
(Jay Pfaffman) #3
Thanks, @falco! It looks like there are backup and restore table_schemas. (And thanks to @supermathie and @omarfilip for editing TWO ridiculously glaring typos! I often wish there were a way to :heart: an edit.)
Should I just
drop schema backup;
drop schema restore;
and I guess the pg_catalog and information_schema are not problems.
Does having those schemas in the database affect performance, or do they just waste disk space (which I usually don’t care that much about).
(And then I guess should also rm -rf postgres_data_old, but that’s another issue.)
(Michael Brown) #4
Naturally, before you do ANYTHING take a backup :smiley:
Is there data in those schemas? They’re used in backup_restore.rb to be able to atomically switch to a restore (the restore schema) or rollback a restore (the backup schema).
They should be safe to drop.
(Jay Pfaffman) #5
I think that’s what I thought, but if I drop them, one will come back when a backup happens and the other when there’s a restore? Sounds a bit feckless to fuss with them. But with them, the database takes basically 3X the footprint, it seems.
