DB will not seed if max post length is reduced
(Sam Saffron) #1
If you set max_post_length to 5000, DB will no longer seed and upgrades will fail.
This happens cause the TOS etc posts are quite long.
@neil they either need to be immune to this limit or you should not be allowed to reduce it that much.
(Jeff Atwood) #2
Probably they should be immune to this limit.
Maybe all Staff posts can be immune? That would make it per category.
(Neil Lalonde) #3
Looks like skip_validations: true doesn’t skip that validation. Should it?
(Jeff Atwood) #4
I would say yes unless someone can offer a compelling reason not to.
(Neil Lalonde) #5
This problem was fixed.
(Sam Saffron) #6
