Default gzip settings?
(Brad Huber) #1
So, like an idiot, the random tutorial I followed (not one of the official ones) never mentioned adding a root password or ssh key to the app.yml file, so I cant ssh into my container. I just want to check the gzip settings in the nginx config, and dont want to shut down the forum, destroy the container, and bootstrap it again unless I need to actually go in there and change anything.
(I’ll need to do it eventually, I know, but I’d rather do that late at night, and I need to know the gzip settings today)
(Tuan Anh Tran) #2
Or you can launch a DO droplet and install diacourse. Wouldnt take more than 30 mins.
I would do it if i can but im on mobile so…
(Jens Maier) #3
Or you could simply update the discourse_docker scripts and run ./launcher enter app as (the host’s) root.
(Brad Huber) #4
Ugh. Thanks. I thought ssh app was the only way in. But that definitely worked!
(Not an Ops guy - just a dev being thrown into that world)
(Sam Saffron) #5
If you are using the default settings: discourse/nginx.sample.conf at master · discourse/discourse · GitHub
(Brad Huber) #6
Thanks! Do you happen to also know what the gzip buffer settings are, since theyre not specifically mentioned in the config? We want to make sure we’re not actually going to use a setting thats a step down.
(Jeff Atwood) #7
I believe @sam set up good gzip defaults recently (early July 2014) in the base Docker image.
After about level 5 there’s no benefit, but you want to be at level 5 for sure.
