Default in sample yml file
(Stephen) #1
Can we please get the default in the sample yml switched over to beta? @sam?
Many of the issues we’ve experienced recently are a result of the sample yml defaulting to tests-passed, and from the other user reports which seem to coincide we’re not alone on that front.
This is our app.yml at the moment
  #version: tests-passed
Notifications, search, goto missing frame
(Sam Saffron) #2
I a fine with switching the default in samples to “beta”
@codinghorror is this ok with you?
(Jeff Atwood) #3
The weekly betas? Sure that is fine.
