Default other enable quoting
(Pad Pors) #1
it says : "Enable quote reply for highlighted text by default. "
when I deactivate this option in the setting menu, it seems it’s still working:
when i highlight some parts of the text, it still shows me "quote reply option.
what does this option in the setting do? and is this a bug, or am i misunderstood?
(Sam Saffron) #2
Reload the page for this to take effect.
(Régis Hanol) #3
Default settings are only applied to new users.
(Pad Pors) #4
have already reloaded the site. may it be cash? and should i rebuild the site ?
do you mean new logins? or is it just new registered users?
the second one seems strange to me.
(Régis Hanol) #5
Sorry, these settings are only applied for newly registered users. They are the default values used when creating a new user.
(Pad Pors) #6
it’s somehow logical, in the sense that an admin sets everything at the beginning of a forum. but sometimes there are un-predicted behavior. and you need to change a setting in the middle of a live forum.
is it possible to apply a setting to all the previous users as well?
(Felix Freiberger) #7
The old users can change the setting for themselves on their preferences page.
Alternatively, you can manually change the setting for all users using the rails console.
(Pad Pors) #8
thanks , is there any howto for using rails console in this case?
(Felix Freiberger) #9
I don’t know a full howto, but I have some inspiration for you :slight_smile:
(Rafael dos Santos Silva) #10
Search is friend!
(Pad Pors) #11
searched already, but with bad terms! included the rails console in the search term which didn’t direct me to any point.
thanks :smiley:
