Delete all users and posts
(Thomas Wilson) #1
Hi folks,
Is there a way for me to delete all users and/or associated content from a discourse installation, without reinstalling from scratch? We’d essentially like a fresh install of discourse but with the previous settings maintained (e.g. smtp settings, logos, s3 etc. etc.)
We could probably do this directly in the postgres DB, but I wanted to check if anyone had any pre-canned SQL we could lift, or if there’s a script which does this for us.
Also – sidenote: when i got a user page in the admin panel, it is blank. Not sure if this is a known bug?
Thanks
(Sam Saffron) #2
no trivial way to do this, I guess you could truncate all tables except for site_settings and nuke the uploads directory.
(Thomas Wilson) #3
Thanks, I’ll give this a go
(Jeff Atwood) #4
Let us know if that works OK.
(Thomas Wilson) #5
Sure - will do. Out of interest, how do you reset try.discourse on a daily basis? Do you rebuild the docker container and simply re-insert the site settings?
(Sam Saffron) #6
Much simpler, we just restore it from backup daily.
(Jeff Atwood) #7
Did this work for you?
(Thomas Wilson) #8
We ended up simply dumping the site_settings table and re-installing on a new DO droplet - a bit cleaner that way :smile:
(colin avolve) #9
Just wondering if another, more elegant apporach, has become available for this?
(Blake Erickson) #10
I just wrote a little ruby app that does this using the API. Just posting here in case anyone needs to do this and as a reminder for me to update the discourse_api gem with the endpoints to do this.
