Determining directionality from javascript
(Noam Yorav-Raphael) #1
Here’s a simple RTL issue that I want to submit a fix to. The arrow to expand the category list should be flipped in RTL directionality. Here’s how it looks now:
The arrow comes from category-drop.js.es6:14:
    return "fa fa-caret-right";
I’d like to add an if, to return "fa fa-caret-left" on RTL directionality. My question is, how do I check what is the directionality.
Thanks,
Noam
(Sam Saffron) #2
Can you test
https://github.com/discourse/discourse/pull/3354
Does it solve this? Does it look good?
#3
its just simple css code
you can find this code in css @noamraph
.fa-caret-right:before {  content: "\f0da";}
and replace with
.fa-caret-right:before {  content: "\f0d9";}
(Noam Yorav-Raphael) #4
Cool! I think this is a good solution, as for example the display of “>” changes according to context.
(Kane York) #5
You should probably scope that CSS tighter, just in case.
(Noam Yorav-Raphael) #6
What about
.fa-caret-right[dir="rtl"]:before { content: "\f0d9"; }
Are the code points of Font Awesome stable?
(Kane York) #7
No, I meant this:
.rtl .category-dropdown-button .fa-caret-right:before { content: "\f0d9";}
