Did I need to backup postgres data before launch cleanup command?
The Problem
Our platform’s discourse is initialized. How can I get the backup
Process
I accidentally clean up and push all yes.
Your forum is still running isn’t it?
Those messages are scary, but you should be fine.
Our forum is still running but is initialized like below.
https://lounge.diverseas.com/
Did you lose all your categories, posts, topics, users etc? If not, head to your admin panel, Backups, and you should be able to create one and download it from there in case you accidentally mess up and lose everything.
@Watercolor_Games Yes, I lost all our categories, posts, topics, users etc. And, I don’t have our backups.
Can I see a copy of your app.yml (passwords removed)
@sam Sure.
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  - "templates/web.ssl.template.yml"
  - "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "80:80"   # http
  - "443:443" # https
params:
  #UNICORN_WORKERS: 3
  DISCOURSE_HOSTNAME: lounge.diverseas.com
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'hidetaka.48691001@icloud.com'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  DISCOURSE_SMTP_ADDRESS: smtp.mailgun.org
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: postmaster@mail.xxxxxxx.com
  DISCOURSE_SMTP_PASSWORD: "xxxxxxxxxxxx"
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  LETSENCRYPT_ACCOUNT_EMAIL: hidetaka.48691001@icloud.com
  ## The CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
#hooks:
#  after_code:
#    - exec:
#        cd: $home/plugins
#        cmd:
#          - mkdir -p plugins
#          - git clone https://github.com/discourse/docker_manager.git
#          - git clone https://github.com/zh99998/discourse-username-localization.git
#          - bash discourse-username-localization/install.sh
run:
You don’t need to drop the database all you need to do is restore it.
If you want to anyway you can
rake db:drop db:init  db:migrate
@pfaffman
I didn’t do that like above. I already accidentally cleanup the data and our forum is initialized like above.
How can I recover it? Is it impossible?
