Did one-click install on Digital Ocean. Set up SMTP using SparkPost. Not receiving Discourse activation email
(Donald) #1
Hello
I created a droplet on Digital Ocean with the Discourse installer. I created an account on SparkPost, created an API key and verified a sending domain forum.mydomain.org
I logged into the droplet using Putty and inputted the following details:
Host: smtp.sparkpostmail.com
Port: 587
Username: SMTP_Injection
Discourse API Key: ******************************************
I logged into the new Discourse install via the IP address, inputted my admin email admin@mydomain.org and username admin. It said that an activation email was sent but I haven’t received anything. I’ve tried multiple times and checked the spam folder.
The only thing I can think of is that I don’t currently have forum.mydomain.org pointed to the Discourse instance in my DNS settings (I’m using AWS Route 53) as I haven’t received a welcome email from Discourse with hosted-by-discourse.com as per the instructions here: Configure your domain name for hosted Discourse
Can somebody please help?
(Joshua Rosenfeld) #2
You’re going to want to go through the email troubleshooting #howto.
If your issue is not resolved after going through the topic, please post the results of each section in the second post here so we can assist further.
(Donald) #3
“Double check the settings in your containers/app.yml file.”
Sorry, but how do I do this? I don’t know how to find this file.
(Felix Freiberger) #4
It should be in /var/discourse/containers/app.yml.
If it’s not there: Can you post a link to the instructions you used for installing Discourse?
(Donald) #5
As in, I don’t know how to access any files at all. After I log into my Digital Ocean droplet using Putty, I am shown this, with seemingly no other option to access files etc.
I followed this: How to use the Discourse One-Click Application on DigitalOcean | DigitalOcean
(Felix Freiberger) #6
These instructions have been updated recently, but the image used is still terribly out of date :cry:
Please create a new droplet using these instructions:
(Christoph) #7
That screen shot says that you have not yet configured discourse. So discourse doesn’t know anything about you or your email, how should it send you a welcome message?
Im not sure what is keeping you from following the instructions that you see when you login so I suggest you try doing that.
Once you completed the setup, you will have to update your discourse so you might as well follow @fefrei’s suggestion and setup a droplet with the latest version right away. But either way should work.
(Donald) #8
Thank you, but I have configured Discourse, multiple times. And then I visit the IP address where my Discourse is hosted, register my admin email, username and password and then it says that an activation email has been sent. I have tried this multiple times and have not received the activation email.
Every time I log into the droplet via Putty, I see those same instructions to configure Discourse, and each time I go through and put in the username, API key etc. and it says that Discourse is now configured.
Anyway, I am going to try deleting the droplet on Digital Ocean and creating a new one, as per Felix’s recommendation.
Cheers
(Joe Buhlig) #9
Something’s off then. I’ve used those one-click installs a handful of times with no issues. After going through the prompts you should be done. If they come up again, I’d kill it and try again.
It might be a good idea to inform Digital Ocean of the issue as well.
#10
I had the same issue with SparkPost. I contacted SparkPost about the issue and they advised me to use an email address that is not role based. I was able to resolve it by changing my email address to something like firstname@domain.tld. In case you still weren’t able to receive Discourse activation email, here is a link to my solution post below.
#11
The Digital Ocean One-Click Install definitely doesn’t configure everything the same as the Discourse installation instructions.
