Direct URL to Sign Up Form
#1
Hello there
I would like to create a URL which redirects to the sign up form for my discourse installation.
I basically want to send out this particular URL to my buyers and hide the “sign up” button completely.
Any ideas?
(Arpit Jalan) #2
That URL should be:
http://forums.example.com/signup
That can be done via CSS, but instead you should consider enabling the setting invite only and sending out invites to your buyers.
(Arpit Jalan) #3
I moved a post to a new topic: Sign Up form is showed on SSO enabled instance
