Disable edit notifications setting not working?
(Joshua Rosenfeld) #1
Want to double check my understanding of the setting disable edit notifications as it does not appear to function as I expected.
I have download remote images to local enabled with a 10% disk space threshold. I’ve also enabled disable edit notification, which I assumed would disable an edit log when a remote image was downloaded by the system user. However, this evening I saw a post with the downloaded local copies of images edit log. Am I understanding the setting correctly?
(Kane York) #2
It still makes the edit logs, it just doesn’t deliver a notification to the post author.
(Joshua Rosenfeld) #3
Ah, ok. That makes sense. I’m not sure how I’d change it at the moment, but would a copy change be accepted to make it more clear?
(Jeff Atwood) #4
It seems pretty clear to me… no edit notifications were generated. Notifications are… notifications.
(Joshua Rosenfeld) #5
Sure are. Very minor, Id like to see “who” isn’t receiving the notification, that would make it clearer for me. I interpreted notification incorrectly as the edit log pencil…
Anyway, no big deal, all clear now.
