Disable "newuser spam host threshold"?
(Tyson N.) #1
Would setting newuser_spam_host_threshold to 0 disable that feature? It isn’t apparent if that would be supported from the inline help text or documentation I can find, or should we just set that to an absurdly high value like 9999?
FWIW, our Discourse instance is a support forum for a SaaS product that our clients implement on their own sites, so it would be common for them to link to their own site repeatedly as needed in support inquiries.
(Jeff Atwood) #2
Setting it to 9999 should be fine.
