Disable SSO While Not Signed In
(Christian Stewart) #1
Hi all,
I enabled SSO accidentally and logged off, now I can’t log back in. How can I reset this setting without being logged in?
Thanks!
(Salman, Freelance Developer) #2
You can ssh into the server or db and update the setting I’m sure, or run rails console and update the model property.
(Christian Stewart) #3
Can I have a bit more details on how to update the setting?
(Adam Capriola) #5
./launcher enter app
rails c
irb > SiteSetting.enable_sso = false
irb > exit
exit
Disable Auth0 plugin
(eriko) #6
You might also have to
SiteSetting.enable_local_logins = true
(system) automatically bumped #7
(Aekansh Dixit) #8
There’s always a backdoor for admin!
https://discourse.example.org/u/admin-login
