Disabled cdn,emoji picture URL error
#1
I disabled cdn, emoji picture use cdn.test.com error URL. Picture does not display properly
After disabling cdn not display the correct URL
(Régis Hanol) #2
If you enable/disable the CDN you must rebake all the posts.
You can do that via the command line
# ssh into your server as the root user
cd /var/discourse # or 'cd /var/docker' if you have an old install
./launcher enter app
rake posts:rebake
Disable CDN causes old images with CDN URL can not be shown
#3
Can not resolve this error
