# Outlook-emoji-reacties verbieden
**URL:** https://meta.discourse.org/t/disallow-outlook-emoji-reactions/380418
**Category:** Feature
**Tags:** completed
**Created:** [26 augustus 2025 om 18:39 UTC](https://meta.discourse.org/t/disallow-outlook-emoji-reactions/380418 "2025-08-26T18:39:10Z")
**Posts on this page:** 3
**Page:** 1
<div class="post-metadata">
### Author: ![supermathie](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/supermathie/32/507518_2.png) [@supermathie](https://meta.discourse.org/u/supermathie)
#### Post date: [26 augustus 2025 om 18:39 UTC](https://meta.discourse.org/t/disallow-outlook-emoji-reactions/380418/1 "2025-08-26T18:39:11Z")
</div>
Continuing the discussion from [Translate "Outlook 365" reactions into Discourse reactions](https://meta.discourse.org/t/translate-outlook-365-reactions-into-discourse-reactions/301198/13):
Since Discourse cannot process Outlook reactions at this time, we can add a header to suppress Outlook clients from sending them.
According to @trs80 and [How to Disable Outlook reactions - o365info](https://o365info.com/disable-outlook-reactions/),
> [@Translate "Outlook 365" reactions into Discourse reactions](https://meta.discourse.org/t/translate-outlook-365-reactions-into-discourse-reactions/301198/11):
> Another option would be to add `x-ms-reactions: disallow` as a header which will suppress the ability to send them.
This will reduce noise from Outlook users on Discourse forums.
In the future if we [add support](https://meta.discourse.org/t/translate-outlook-365-reactions-into-discourse-reactions/301198) for them, we can remove the suppression header from topic emails.
### Author: ![sam](https://sea3.discourse-cdn.com/meta/user_avatar/meta.discourse.org/sam/32/102149_2.png) [@sam](https://meta.discourse.org/u/sam)
#### Post date: [29 oktober 2025 om 04:57 UTC](https://meta.discourse.org/t/disallow-outlook-emoji-reactions/380418/2 "2025-10-29T04:57:05Z")
</div>
Done per:
> <https://github.com/discourse/discourse/pull/35674?1>
> Per https://meta.discourse.org/t/disallow-outlook-emoji-reactions/380418
> outloo…k has a feature where you can react to an email with an emoji, this
> leads to noise replies on Discourse forums, disable it.
#### Post date: [29 oktober 2025 om 07:27 UTC](https://meta.discourse.org/t/disallow-outlook-emoji-reactions/380418/3 "2025-10-29T07:27:04Z")
</div>
