Discourse API Documentation
api
#213
While I’m making requests, it would be great to get some documentation on the track_visit query parameter. I’ve seen that used from the API but it isn’t in the docs.
(Roman Hotsiy) #214
Hey, @blake. ReDoc author is here.
You have a really huuuge spec. You event beat our record - your spec is 119 meters tall when rendered by ReDoc :slight_smile:
I’ve found a few ReDoc bugs reproducible on your spec. Will try to fix for the next release.
I’ve also noticed you didn’t add your logo to ReDoc. To add it use x-logo vendor extension.
Maybe you would be interested in our other project GitHub - Rebilly/generator-openapi-repo: 🤖 Yeoman generator for OpenAPI/Swagger repo to help you share spec for your API. It is a tool that helps setting up a repository for OpenAPI spec with a bunch of useful features like validation, splitting spec into smaller manageable chunks and auto-bundling as a CI step.
Let me know if you need any assistance/help with ReDoc. Would be glad to help out :slight_smile:
(Blake Erickson) #215
@RomanHotsiy thank you for the work you do on ReDoc and for the tips! I’ll work on those :wink:
(Erlend Sogge Heggen) #216
(Blake Erickson) #217
I fixed most of the type: null statements and added the discourse logo.
(Manzarul Haque) #218
Hi i am able to run the discourse on my local windows system. How can i generate api key
(Blake Erickson) #219
You can generate an API key by going to Admin → API → Generate API Key
