Discourse box went down with a 500 error, not sure why
(Jared Lerner) #1
Hi -
I was editing some s3 settings in the discourse UI when our site went totally down. Here’s the console output:
I checked the error log at /opt/bitnami/apache2/logs but it doesn’t seem to help. Is there anywhere else I can look for info on this?
Thanks,
Jared
(Rafael dos Santos Silva) #2
Bitnami + Apache isn’t really supported here.
Since this is very custom, did you try to reboot the machine?
(Jared Lerner) #3
Tried rebooting it several times, all to no avail unfortunately.
Here’s the tail end of the error log (after the last reboot)
Didn’t realize this wasn’t supported here. Do you know where it is?
(Rafael dos Santos Silva) #4
I guess the Bitnami folks are the only supporting it.
To get a standard and supported install you can use the docker install guide.
