Discourse, Docker, Container question
(Mark) #1
I’m embarrassed to ask this so I’ll tell you what I emagine and correct me.
  • Running launcher from the /var/discourse directory sets up all necessary Container files including a database, nginx configs.
  • The nginx configs point incoming example.com/ traffic to /var/discourse
  • The magic happens and all is well
So I want to add a php based cms to the mix I should…
I do not want to use WP
(Mariano Rodriguez) #2
I think all you need to do, is follow this guide
