Discourse Docker Images
(Edwin) #1
I recently installed Discourse on a VPS and out of curiosity I decide to find out what Docker was. I got to know the basics and I decided to run the command docker images and I found out that my installation has three images related to discourse. Are they all required for discourse to run smoothly? I have attached the command output below.
(Gurudatt) #2
Whenever you try to remove a docker image, using docker rmi <image_name> command,
If there is a container that is using that image then docker-cli won’t let you delete that image. Instead, it will throw an error, so go ahead try it out :slight_smile:
