Discourse docker subfolder bugs and problems
I am trying to set up subfolder discourse I am having a lot of problems setting it up
I used this documentation for installing subfolder discourse
Problems
  1. My first problem was default logo is not working it’s searching the logo on the root directory.
    this problem was solved when i uploaded my own logo
  2. images are getting 404 after rebuilding
  3. avatars are disappearing after restoring the backup and rebuilding
I think the upload section of the subfolder discourse is not working correctly
I have tried to remap but that’s not working
Here’s my app.yml
##   Subfolder support with Docker   https://meta.discourse.org/t/subfolder-support-with-docker/30507
## discourse-terraform Docker configuration template
## After making changes to this file, you MUST rebuild for any changes
## to take effect in your live Discourse instance:
## this is the all-in-one, standalone Discourse Docker container template
# You may add rate limiting to by commenting out the ratelimited template.
# Out of the box it allows 12 reqs a second per ip, and 100 per minute per ip
# This is configurable by amending the params in this file
templates:
  - "templates/sshd.template.yml"
## which TCP/IP ports should this container expose?
expose:
  - "1357:80" #change this port to port where you want run discourse # fwd host port 80   to container port 80 (http)
  #- "2222:22" # fwd host port 2222 to container port 22 (ssh)
params:
  ## Set db_shared_buffers to 1/3 of the memory you wish to allocate to postgres
  ## on 1GB install set to 128MB on a 4GB instance you may raise to 1GB
  db_shared_buffers: "512MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  ## TODO: How many concurrent web requests are supported?
  ## With 2GB we recommend 3-4 workers, with 1GB only 2
  UNICORN_WORKERS: 3
  ## on initial signup example 'user1@example.com, user2@example.com'
  DISCOURSE_DEVELOPER_EMAILS: "ahmeds.works@gmail.com" #change these emails to site admins emails
  DISCOURSE_RELATIVE_URL_ROOT: /ask
  DISCOURSE_HOSTNAME: "privitevps.ga" #change this domain to you website domain
  ## TODO: The mailserver this Discourse instance will use
  # change smtp setting to your own smtp setting
  DISCOURSE_SMTP_ADDRESS: smtp-relay.example.com
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: example@gmail.com
  DISCOURSE_SMTP_PASSWORD: smtp_password
  ## The CDN address for this Discourse instance (configured to pull)
  #DISCOURSE_CDN_URL: //discourse-cdn.example.com
## These containers are stateless, all data is stored in /shared
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## The docker manager plugin allows you to one-click upgrade Discouse
## http://discourse.example.com/admin/docker
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - mkdir -p plugins
          - git clone https://github.com/discourse/discourse-voting.git
## Remember, this is YAML syntax - you can only have one block with a name
run:
    - exec:
        cd: $home
        cmd:
          - rm -fr public/assets
          - sudo -E -u discourse bundle exec rake assets:precompile
          - mkdir -p public/ask
          - cd public/ask && ln -s ../uploads && ln -s ../backups
          - rm public/uploads
          - rm public/backups
    - replace:
       global: true
       filename: /etc/nginx/conf.d/discourse.conf
       to: |
          rewrite ^/(.*)$ /ask/$1 break;
          proxy_pass http://discourse;
    - replace:
       to: |
          etag off;
          location /ask {
             rewrite ^/ask/?(.*)$ /$1;
    - replace:
         to: $http_fastly_client_ip
         global: true
    - exec: awk -F\# '{print $1;}' ~/.ssh/authorized_keys | awk 'BEGIN { print "Authorized SSH keys for this container:"; } NF>=2 {print $NF;}'
here’s my Nginx config
    location /ask {
        proxy_pass      http://localhost:1357/ask;
        proxy_read_timeout      90;
        proxy_redirect  http://localhost:1357/ask https://privitevps.ga/ask;
@neil can you plz help me install discourse on the subdirectory without any error
