Discourse doesnt load after increase of the size
Hi. We got in the morning one warning about the backup not being able to be created. After that we checked the size on the server and found that is low. We increased the size of the VM in Azure where the discourse is installed and now seems that the discourse cannot be accessible at all. I tried rebuild and same thing.
netstat -ltnp (in docker)
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:6379            0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      347/nginx
tcp        0      0 0.0.0.0:3000            0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:5432            0.0.0.0:*               LISTEN      -
tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      347/nginx
tcp6       0      0 :::6379                 :::*                    LISTEN      -
tcp6       0      0 :::5432                 :::*                    LISTEN      -
and on server
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      1248/sshd
tcp6       0      0 :::80                   :::*                    LISTEN      15937/docker-proxy
tcp6       0      0 :::22                   :::*                    LISTEN      1248/sshd
tcp6       0      0 :::443                  :::*                    LISTEN      15925/docker-proxy
Any suggestions?
Thank you
Can you check the logs from docker and see what is happening?
run-parts: executing /etc/runit/1.d/00-ensure-links
run-parts: executing /etc/runit/1.d/00-fix-var-logs
run-parts: executing /etc/runit/1.d/anacron
run-parts: executing /etc/runit/1.d/cleanup-pids
Cleaning stale PID files
run-parts: executing /etc/runit/1.d/copy-env
run-parts: executing /etc/runit/1.d/letsencrypt
[Thu Jul 11 14:36:43 UTC 2019] Domains not changed.
[Thu Jul 11 14:36:43 UTC 2019] Skip, Next renewal time is: Fri Jul 19 00:19:10 UTC 2019
[Thu Jul 11 14:36:43 UTC 2019] Add '--force' to force to renew.
[Thu Jul 11 14:36:43 UTC 2019] Installing key to:/shared/ssl/.......org.key
[Thu Jul 11 14:36:43 UTC 2019] Installing full chain to:/shared/ssl/.........org.cer
[Thu Jul 11 14:36:43 UTC 2019] Run reload cmd: sv reload nginx
fail: nginx: runsv not running
[Thu Jul 11 14:36:43 UTC 2019] Reload error for :
Started runsvdir, PID is 335
ok: run: redis: (pid 344) 0s
ok: run: postgres: (pid 346) 0s
rsyslogd: command 'KLogPermitNonKernelFacility' is currently not permitted - did you already set it via a RainerScript command (v6+ config)? [v8.16.0 try http://www.rsyslog.com/e/2222 ]
rsyslogd: imklog: cannot open kernel log (/proc/kmsg): Operation not permitted.
rsyslogd: activation of module imklog failed [v8.16.0 try http://www.rsyslog.com/e/2145 ]
rsyslogd: Could not open output pipe '/dev/xconsole':: No such file or directory [v8.16.0 try http://www.rsyslog.com/e/2039 ]
supervisor pid: 342 unicorn pid: 373
