Discourse is down after `launcher rebuild app`
Hi all,
I was trying to upgrade Discourse from 2.0 to 2.0.1 on my website, and it showed something like this:
But after running ./launcher rebuild app, the website is not available anymore. Any ideas?
Thanks,
Yinglu
Did you get any errors while ./launcher rebuild app
Your database may have upgraded, consider running ./launcher rebuild app once again
I remembered during the rebuilding, Postgres was upgraded from 9.5 to 10, and I got an error mentioned in this post, which is
WARNING: Upgrading PostgresSQL would require an addtional 19M of disk space
So I have run docker system prune to get some free space and rerun ./launcher rebuild app, then it succeeded.
I have tried running ./launcher rebuild app several times but no luck. Anyway I will run it again to see if it helps.
I’d say you should’ve tried running ./launcher cleanup as against docker system prune first.
in case that is not helping, try pulling the latest commit from server and then rebuild:
cd /var/discourse
git pull
in case you encounter any errors, make sure to post them below.
I have tried
./launcher cleanup
docker system prune
cd /var/discourse
git pull
No luck. I doubt the upgrade of Postgres has destroyed the database, and I have seen
postgres@postgres ERROR: database "discourse" already exists
In the build log. Any ideas?
The system should have backup of Postgres 9.5 stored somewhere on your filesystem.
Please refer this topic!
Asked for a professional OP engineer’s help and it turned out that there were something wrong with my nginx and CDN config, and the problems were possibly triggered by Discourse upgrade. I don’t know the details but after his operation, everything worked as expected.
Thanks @itsbhanusharma for helping!
