Discourse letsencrypt not working
Hi, i’m not receiving a certificate from letsencrypt. Currently my website is not working at all, i get ‘This site can’t be reached. dutchfurs.nl refused to connect.’. Does anyone have a clue how i can fix this? Thanks!
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
  - "templates/web.ssl.template.yml"
  - "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "80:80"   # http
  - "443:443" # https
params:
  db_shared_buffers: "128MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LANG: en_US.UTF-8
  UNICORN_WORKERS: 2
  DISCOURSE_HOSTNAME: dutchfurs.nl
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'kimwillemstein@live.nl'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  DISCOURSE_SMTP_ADDRESS: smtp.mailgun.org
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: postmaster@mg.dutchfurs.nl
  DISCOURSE_SMTP_PASSWORD: "passhere"
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  LETSENCRYPT_ACCOUNT_EMAIL: myemail@live.nl
  ## The CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  #DISCOURSE_CDN_URL: //discourse-cdn.example.com
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
run:
Likely not related to this announcement - the TLS-SNI challenge is a different authentication method of proving control that turns out to be exploitable on shared hosts.
@FuzzerFox’s setup is using the HTTP verification method, but it’s returning a 404 on the challenge. It’s possible the challenge didn’t make it back to the right web server.
Hey, @itsbhanusharma, I thought that TLS thing might be related too & have been wondering about it since I saw those messages.
And just to be sure, I just did a standard install with Let’s Encrypt and it worked just fine.
I’ll try a dry run tomorrow to test if it works.
I recall I had to issue certs in standalone mode to fix ssl renewal problem on my side. But maybe it was a temporary issue.
If you did what I think you’re saying, then you are not using the standard Discourse Let’s Encrypt stuff.
If i buy a ssl certificate from namecheap, would that cause any issues? I just want ssl and don’t mind paying 7$ for a year if that works
Are you using a standard install or do you have an nginx running outside the container?
I think standard install, i used this tutorial : How To Install Discourse on Ubuntu 16.04 | DigitalOcean
Visiting http://dutchfurs.nl gives a plane that says “not found”. A standard install doesn’t do that. Are you running a multi site instance?
