Discourse migration images issue
(Awrelll) #1
Hello,
I just moved my discourse instance on a subdomain and now all my images are not displayed because of the bad links.
Is there any way to “batch” update image links so they can be correctly displayed ?
My ex domain.com diplayed the discourse and now it’s forum.mydomain.com
Thanks in advance :smile:
(Jens Maier) #2
Did you follow the howto? :smile:
The last step, remap & rebake, should have fixed the image links.
(Awrelll) #3
Hey, thanks for your reply. It seems it’s now working for me, when i try a remap i get this error “discourse: command not found” and when trying to rebake “root@install:/var/discourse# rake posts:rebake
rake aborted!
No Rakefile found (looking for: rakefile, Rakefile, rakefile.rb, Rakefile.rb)”
Any clues ?
(Kane York) #4
You need to ./launcher enter app first :wink:
(Awrelll) #5
I did that first! that returned “root@install:/var/discourse# ./launcher enter app
WARNING: No swap limit support
nsenter: neither filename nor target pid supplied for ns/ipc”
(Kane York) #6
Oh, try ./launcher ssh app then, I think that means it failed.
Actually, is the forum actually running? It needs to be running to do this stuff.
(Awrelll) #7
still no luck, same errors :frowning:
