Discourse not installing on Ubuntu
#1
Okay, so I’m installing Discourse on Ubuntu.
In PuTTY, after stating my hostname, admin email, etc. I received the following error:
(): did not find expected key while parsing a block mapping at line 40 column 3 -e LANG=en_US.UTF-8
YAML syntax error. Please check your containers/*.yml config files.
I inserted everything correctly, and my key for my SMTP is correct. Can someone help me?
#2
You should check the app.yml in a yaml validator : Best YAML Validator Online
Around ilne 40, it should look like this :
env:
  LANG: en_US.UTF-8
  DISCOURSE_DEFAULT_LOCALE: en
(Jay Pfaffman) #3
Did you run discourse-setup?
Did your smtp password have funny characters?
#4
How can I check the app.yml?
#5
To access your app.yml type these commands:
cd /var/discourse
nano containers/app.yml
Or download it on your ftp in the folder : /var/discourse/containers
(Jay Pfaffman) #6
It’s likely easiest to delete app.yml and run discourse-setup.
#7
Checked the yml. It says exactly what its supposed to say at around line 40.
#8
Deleting it actually works?
(Jay Pfaffman) #9
Unless you have some custom needs, deleting app.yml and running discourse-setup is the best thing to do.
