Discourse not working after upgrade fail
admin
docker
(Anand) #1
I was not able to upgrade from admin panel, so i used the following command to upgrade via ssh
cd /var/discourse
git pull
./launcher rebuild app
It also failed. Here is the error
And now the site is also not working. What to do?
(Jeff Atwood) #2
I am guessing you have plugins installed? Try removing them.
(Anand) #3
I have installed Tagging Plugin just before this upgrade. Should i remove them all or just tagging plugin.
Can you please suggest link to instructions for disabling / removing specific plugin from discourse.
(Jeff Atwood) #4
Edit your app.yml file to remove the plugin. There is a howto category post here on adding plugins, so follow that in reverse.
(Anand) #5
After removing all plugins (Adsense & Tagging) it is upgraded successfully. How to get plugins back; Install again or there is conflict with plugins in this version?
(Jeff Atwood) #6
If it is a plugin we build, it will be compatible.
(Anand) #7
Thank for the support. I shifted from vBulletin to Discourse and I am loving it.
