Discourse Preview Not Working
(Shukazé) #1
Discourse Version: 1.9.0.beta5
I’ve ran into a particular problem with the preview, it doesn’t show content on any browser since I’ve updated it from ~1.7
I don’t know what’s wrong, have I missed something that I needed to do?
(Joffrey Jaffeux) #2
Could hou try to use safe mode and see if it works without plugins How to use Discourse Safe Mode
(Shukazé) #3
Here’s a screenshot when in safemode:
(Joffrey Jaffeux) #4
Then watch your logs/browser console for any error.
(Shukazé) #5
I’ve got the latest log that dates back to the 21st of July 2017 which reads:
TypeError: Cannot read property ‘create’ of undefined
at https://forum.fmisgaming.com/assets/vendor-199fce5a9e9895329b51b04605f1f5061951acb488baa6b2ea2fc2ae36def529.js:6:31982
at https://forum.fmisgaming.com/assets/vendor-199fce5a9e9895329b51b04605f1f5061951acb488baa6b2ea2fc2ae36def529.js:7:994
(Shukazé) #6
I’m just gonna backup and nuke it all and reinstall it. Hopefully this will fix it.
(Shukazé) #7
I’ve nuked it and all and it still doesn’t work. Please tell me specific commands or urls to provide more information for you, I am really stumped right now.
What I did:
Is it really the swap? Mines set to 255MB and it’s recommended for 2048MB, my docker info is:
Containers: 1
 Running: 1
 Paused: 0
 Stopped: 0
Images: 4
Server Version: 17.05.0-ce
Storage Driver: aufs
 Root Dir: /var/lib/docker/aufs
 Backing Filesystem: extfs
 Dirs: 26
 Dirperm1 Supported: true
Logging Driver: json-file
Cgroup Driver: cgroupfs
Plugins:
 Volume: local
 Network: bridge host macvlan null overlay
Swarm: inactive
Runtimes: runc
Default Runtime: runc
Init Binary: docker-init
containerd version: 9048e5e50717ea4497b757314bad98ea3763c145
runc version: 9c2d8d184e5da67c95d601382adf14862e4f2228
init version: 949e6fa
Kernel Version: 3.16.0-4-amd64
Operating System: Debian GNU/Linux 8 (jessie)
OSType: linux
Architecture: x86_64
CPUs: 2
Total Memory: 3.873GiB
Docker Root Dir: /var/lib/docker
Debug Mode (client): false
Debug Mode (server): false
Registry: https://index.docker.io/v1/
Experimental: false
Insecure Registries:
 127.0.0.0/8
Live Restore Enabled: false
WARNING: No memory limit support
WARNING: No swap limit support
WARNING: No kernel memory limit support
WARNING: No oom kill disable support
WARNING: No cpu cfs quota support
WARNING: No cpu cfs period support
Will proceed with steps provided: https://meta.discourse.org/t/how-to-install-docker-with-aufs-on-linode/39831
Let’s see how this goes.
Welp, I already had all this set besides the swap size, preview still doesn’t work. Ideas @joffreyjaffeux ?
(Jeff Atwood) #8
Do you have any third-party plugins installed? They are notorious for causing breakage on upgrade. Remove any third-party plugins you have installed.
(Shukazé) #9
If you mean by third party plugins via app,yml then I removed everything but the defaults. Is this maybe a docker or redis issue?
…what I mean by defaults is that it’s empty.
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
(Sam Saffron) #10
Wait a sec, what web browser are you using? Does this happen here?
#11
@sam I have tried this both on Firefox and Chrome and it doesn’t work, but while I’m writing this, it works so it should not be browser-based issue
#12
I experience the same issue in the latest Version: 1.9.0.beta7
(Jeff Atwood) #13
Unless it also happens here and/or on https://try.discourse.org, this is a configuration error with your Discourse.
#14
Your comment actually brought me to the solution.
Here is the thing: I moved discourse to a new server. Made a backup of the old discourse, setup a new instance on the new server and imported the old backup. So i was sure it was no setting error.
But thanks to your answer i checked the old server/discourse instance and got the same ‘issue’ somewhere it loads an insecure script.
it seems this script is loaded via http but https http://forum.xxx.tld/assets/markdown-it-bundle-95eab67cdea904c1edf468e5ed93ba3d0ed27da63e4428828e8a566506f74391.js
(sorry for the german) it is the browser that stopped a skript from not authenticated source. Not sure why this happens cause i got SSL installed just not enforced since this hadn’t worked in the past and everything was fine
All sites are loaded as https and it got everywhere the green lock.
#15
Update: I have now ‘force ssl’ enabeled still it loads the script via http
Q. is there any .htaccess equivalent for discourse? to rout all request to that url to https?
#16
@codinghorror is there an option to set https for scripts manually. Like gradually enforcing it not like black and white how it is now.
#17
Might relate to this issue: [Solved] Dev instance with nginx: topic preview not working
#18
unfortunately not.
i believe the apache proxy setup i have does not work for this. Somehow everything works fine as long as i don’t force https.
If i do i end up with and too many redirects because of the SSO provider.
Shame one can not enforce https gradually. only with base url change i would do it. cause script is reachable through https but discourse seems not to get it
(xiasummer) #19
Hi, I’m using the newest Discourse 1.9.0 beta7
Any idea why this happens?
Discourse assign
(Joshua Rosenfeld) #20
Hmm @sam here’s another report…
