Discourse refusing connections
hello I was running my own site and I set it up to get a feel for it well I deleted everything and reinstalled my VPS because I tried resetting it and it failed well now it’s just refusing connections when I redid the whole entire process
I’m using cloudflare as my DNS I turned off proxy so it wouldn’t use its CDN I even cleared it just to make sure
I’ve even made sure that the ports are open
I fixed it I had to disable let’s encrypt I don’t even need it though since my DNS gives me a certificate
