Discourse sending huuuuge number of emails
(Thomas Eichstädt-Engelen) #1
Hi,
we are currently facing the problem of discourse sending huge number of emails day by day (our SMTP account have been deactivated by our provider meanwhile). Since the sent emails are counted in the forums’ “Email sent” statistic i assume the forum sends all these emails itself (somehow).
2015-10-19 63282
2015-10-18 51312
2015-10-17 46798
2015-10-16 23993
2015-10-15 21865
2015-10-14 41705
2015-10-13 48321
2015-10-12 48213
2015-10-11 34591
2015-10-10 32146
2015-10-09 29282
2015-10-08 26931
2015-10-07 15779
2015-10-06 9697
2015-10-05 7684
Depending on the number of users i would expect something around 10.000 to be normal. Any idea which trail to follow in order to find the culprit? Is there any statistic showing the amount of emails by user?
Any help appreciated, Thomas E.-E.
(Dean Taylor) #2
Your first point of call would be here:
/admin/email/sent
This shows you the type of emails and to who.
If your site / content has been recently imported into Discourse…
… did you ensure sending emails was disabled during import?
it might be background tasks from the import sending the emails.
Consider checking /sidekiq for a long list of queued tasks.
(Thomas Eichstädt-Engelen) #3
Hi @DeanMarkTaylor,
wasn’t aware of this functionality, thanks!
It says:
Sent At	User	To Address	Email Type	Reply Key
Filter
1 min	—	Mailer-Daemon@ispgateway.de	email_reject_empty
ispgateway.de is one of the domains of your email provider.
We have activated email polling … something in combination with that?
Thanks, Thomas E.-E.
(Dean Taylor) #4
I remember something about a loop of emails being sent to yourself… causing a rejection email… which again sends to itself.
Consider disabling polling for now.
and check your mail settings
have a search around the forum - I can’t remember the exact topic.
(Thomas Eichstädt-Engelen) #5
found issues like Email reply system issue sent a million unwanted mails which describes the same behaviour but didn’t find a solution since we configured the reply email address accordingly.
