Discourse shows blank page when JavaScript is partially blocked
javascript
(_Vi) #1
I go to forum and see just a white page. Enabling JavaScript for this domain reveals a Discourse instance.
Better options are:
  1. Fully allowing participating without JavaScript (except of nice features);
  2. Showing just read-only basically formatted content (like for the search engines);
  3. Showing “This is a Discourse forum. It requires javascript.”-like message.
(Régis Hanol) #2
We already do a mix of all 3 techniques :wink: What browser are you using and how are you disabling JS?
(TechnoBear) #3
I have long had this issue, although it’s discourse.global.ssl.fastly.net that I have to enable, rather than the domain.
Currently Firefox 38 on Ubuntu Gnome 15.04, but it affected earlier versions of both browser and OS. I use NoScript to block JS, because then I can allow some scripts and block others, (rather than an all-or-nothing approach) which (hopefully) lets me enable stuff I need to use a site whilst still blocking anything which causes visual/perceptual problems.
(_Vi) #4
For example, https://forum.safenetwork.io/.
If I select “Forbid safenetwork.is” in NoScript and reload a page, I see just a while screen.
There are errors in console:
ReferenceError: PreloadStore is not defined
PreloadStore.store("site",{"default_archetype":"regular","notification_types":{"...
forum.s...work.io (line 212, col 8)ReferenceError: Ember is not defined
Ember.RSVP.configure('onerror', function(e) {
forum.s...work.io (line 234, col 2)ReferenceError: Discourse is not defined
Discourse.CDN = '';
I think Discourse should detect partially blocked JavaScript and show the approriate message and/or show no-JS variant of the page in this case.
(TechnoBear) #5
That’s strange. Without allowing safenetwork.io in NoScript, I see this:
Which is similar to what I see here or on SitePoint with JS disabled. The issue for me is if I enable JS for the domain, but don’t enable it for discourse.global.ssl.fastly.net (or sitepoint-discourse.global.ssl.fastly.net) I then get a blank page.
(_Vi) #6
I don’t see any references to fastly.net (in Firebug or NoScript). And “fastly.net” is in NoScript’s whitelist.
(Kane York) #7
This was fixed by one of my old PRs which got rejected:
https://github.com/discourse/discourse/pull/3105
Basically, it changed
<noscript>
into
<div id='noscript'>.....</div><script>var ns = document.getElementById('noscript'); ns.parentNode.removeChild(ns);</script>
(Jeff Atwood) #8
Step 1 – disable JavaScript in Firefox
Step 2 – visit meta.discourse.org
Premise of topic is 100% incorrect. I am editing the title. If you partically block JavaScript, that’s on you.
(_Vi) #9
I think common partial JavaScript cases (allowed the domain, disallowed everything else + allowed everything except of this domain) should also be handled.
It is tricky to enable just Discourse instance on the given site without enabled all other JavaScripts from this site.
