Discourse SSO / Iframe
Hi i’m currently building my Discourse. I was searching to include sso when i saw this post. I may have missunderstood so i would like to ask if it was possible to have BOTH SSO on and the content of the forum in an Iframe.
Thanks you
We’ ve been a bit further, and now we have this logs error:
Info:
TypeError (no implicit conversion of nil into String)
/var/www/discourse/lib/single_sign_on.rb:103:in `hexdigest’
/var/www/discourse/lib/single_sign_on.rb:103:in `hexdigest' /var/www/discourse/lib/single_sign_on.rb:103:in `sign' /var/www/discourse/lib/single_sign_on.rb:56:in `parse' /var/www/discourse/app/controllers/session_controller.rb:111:in `sso_login' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/base.rb:194:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/rendering.rb:30:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/callbacks.rb:42:in `block in process_action' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/callbacks.rb:132:in `run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/callbacks.rb:41:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/rescue.rb:22:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications.rb:168:in `block in instrument' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications/instrumenter.rb:23:in `instrument' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/notifications.rb:168:in `instrument' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/instrumentation.rb:32:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal/params_wrapper.rb:256:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.0/lib/active_record/railties/controller_runtime.rb:24:in `process_action' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/abstract_controller/base.rb:134:in `process' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionview-5.2.0/lib/action_view/rendering.rb:32:in `process' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiling_methods.rb:78:in `block in profile_method' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal.rb:191:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_controller/metal.rb:252:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:52:in `dispatch' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:34:in `serve' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:52:in `block in serve' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:35:in `each' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/journey/router.rb:35:in `serve' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/routing/route_set.rb:840:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-protection-2.0.3/lib/rack/protection/frame_options.rb:31:in `call' /var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:24:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/tempfile_reaper.rb:15:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/conditional_get.rb:25:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/head.rb:12:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/http/content_security_policy.rb:18:in `call' /var/www/discourse/lib/middleware/anonymous_cache.rb:212:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:232:in `context' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/session/abstract/id.rb:226:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/cookies.rb:670:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/activesupport-5.2.0/lib/active_support/callbacks.rb:98:in `run_callbacks' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/callbacks.rb:26:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/logster-1.2.11/lib/logster/middleware/reporter.rb:31:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/rack/logger.rb:38:in `call_app' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/rack/logger.rb:28:in `call' /var/www/discourse/config/initializers/100-quiet_logger.rb:16:in `call' /var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/remote_ip.rb:81:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/request_id.rb:27:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/method_override.rb:22:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/actionpack-5.2.0/lib/action_dispatch/middleware/executor.rb:14:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/sendfile.rb:111:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-mini-profiler-1.0.0/lib/mini_profiler/profiler.rb:174:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/message_bus-2.1.5/lib/message_bus/rack/middleware.rb:63:in `call' /var/www/discourse/lib/middleware/request_tracker.rb:180:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/engine.rb:524:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in `public_send' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/railties-5.2.0/lib/rails/railtie.rb:190:in `method_missing' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/urlmap.rb:68:in `block in call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `each' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/rack-2.0.5/lib/rack/urlmap.rb:53:in `call' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:606:in `process_client' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:701:in `worker_loop' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:549:in `spawn_missing_workers' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/lib/unicorn/http_server.rb:142:in `start' /var/www/discourse/vendor/bundle/ruby/2.5.0/gems/unicorn-5.4.0/bin/unicorn:126:in `<top (required)>' /var/www/discourse/vendor/bundle/ruby/2.5.0/bin/unicorn:23:in `load' /var/www/discourse/vendor/bundle/ruby/2.5.0/bin/unicorn:23:in `<main>'`
Env:
application_version f0b551b6847541df13531fbe05f2587b6edc9241
HTTP_HOST forum.CENSORED.com
REQUEST_URI [/session/sso_login, /session/sso_login?https://forum.CENSORED.com/session/sso_login?sso=bm9uY2U9MzRmMTVlYmI5NTIzZWJmMGUzYmRjMWU2NTQyZTEyMTImZW1haWw9emFjZUBkdW1vYWMubmV0JmV4dGVybmFsX2lkPTIwJnVzZXJuYW1lPUNsJUMzJUE5bWVudCZuYW1lPUNsJUMzJUE5bWVudCZhZG1pbj1mYWxzZSZtb2RlcmF0b3I9ZmFsc2U&sig=d88ecd8beccf15dd07dd4e34b92ad44197b03fac66625e9d0a9a89952098330a]
REQUEST_METHOD GET
HTTP_USER_AGENT [Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:61.0) Gecko/20100101 Firefox/61.0, Mozilla/5.0 (Macintosh; Intel Mac OS X 10_13_5) AppleWebKit/605.1.15 (KHTML, like Gecko) Version/11.1.1 Safari/605.1.15, Slackbot-LinkExpanding 1.0 (+https://api.slack.com/robots)]
HTTP_ACCEPT [/, text/html,application/xhtml+xml,application/xml;q=0.9,/;q=0.8]
HTTP_X_FORWARDED_FOR [178.208.16.92, 82.228.255.199, 34.228.6.255, 54.152.0.39]
HTTP_X_REAL_IP [178.208.16.92, 82.228.255.199, 34.228.6.255, 54.152.0.39]
params
https://forum.CENSORED.com/session/sso_login?sso [null, bm9uY2U9MzRmMTVlYmI5NTIzZWJmMGUzYmRjMWU2NTQyZTEyMTImZW1haWw9emFjZUBkdW1vYWMubmV0JmV4dGVybmFsX2lkPTIwJ]
sig [null, d88ecd8beccf15dd07dd4e34b92ad44197b03fac66625e9d0a9a89952098330a]
Question that might help get some answers. What are you using to provide SSO service to discourse.
We have coded SSO support on our own server and so far, login the user in works fine, although it triggers the internal error above
