Discourse Upgrade Leading to HTTP Error 500
#1
And nothing shows up in the logs. What steps do I take to diagnose the issue? Thanks!
(Rafael dos Santos Silva) #2
Can you please try rebuilding?
Please SSH into your server and run:
cd /var/discourse
git pull
./launcher rebuild app
(Peter Salzmann) #3
Since day 1 of installing and rebuilding Discourse I’ve had no problems. I just noticed the line you’re using isn’t the same as what I do. I don’t do the git pull line. Is that a problem? doesn’t the ./launcher rebuild app do that part for you?
Should I use the git pull line or not?
Thanks in advance.
#4
Yes you should always use git pull before a rebuild
(Peter Salzmann) #5
Thanks Steven. I’ll start doing that. :slight_smile:
(Felix Freiberger) #6
I‘m pretty sure launcher started to auto-pull some time ago, so doing it once (to make sure you have a version that does this) should be enough :slightly_smiling_face:
