Discourse URL tracking prevents proper redirects
(Sam Nazarko) #1
Hi
I have recently migrated a Discourse install by making a backup and then restoring it. It seems now that URL redirection is broken.
See Changing Webserver to Port 80 - Raspberry Pi - OSMC Forums. There I post a GitHub commit. Clicking on it seems to try and redirect me to the domain that is hosting the forum.
Thanks
Sam
(Jens Maier) #2
Blind guess: did you try rake posts:rebake ?
(Sam Nazarko) #3
root@discourse-app:/# rake posts:rebake
Rebaking post markdown for 'default'
     1937 / 1937 (100.0%)
1937 posts done!
It ran, but doesn’t seem to have helped
(Mark Theis Madsen) #4
Discourse is treating external urls as internal. So when I click on a link it strips the domain and goes to Discourse Meta in ajax instead of http://externalsite.com/someurl.
(Jeff Atwood) #5
Looks like you have bad site settings somewhere, or perhaps app.yml has the domain name specified incorrectly.
(Mark Theis Madsen) #6
I have checked through the site settings, the app.yml and the other yml templates. Everything seems fine.
And I just noticed that internal urls opens like external urls should. without an ajax request.
(Sam Nazarko) #7
You may remember I posted here about having issues using the Pound load balancer. This has been the course of the problem yet again.
I set up a dedicated box for Discourse and used the Ubuntu 14.04 (trusty) version of Pound installed via apt-get. I did this as I was no longer using SNI (dedicated IPV4 for the service) and thus no longer needed bleeding edge (Pound SNI and SAN matching / Filidor Wiese <fili@fili.nl>)
I noticed that going through HTTP only with an /etc/hosts change was fine, indicating it is the load balancer.
As only recent versions of Pound have “Certificate alternate names support”, I believe that Pound was setting the wrong request URL. I confirmed this with some logging in the Varnish VCL. This was causing the issue
