Discourse with ec2 doubt
(Marcos P) #1
Hello, I am currently running an ec2 instance of 2gb ram, running nginx 1.9.10 and php 5.5.31, but the ruby is not installed at this instance, my question is, could I run a discourse on the same machine without getting in the way The site already hosted in wordpress?
(Felix Freiberger) #2
This should work fine, but needs some additional setup. If you want to avoid that, install to a new host – otherwise, these instructions can help:
They assume that you already have a running Discourse install and do not have nginx running already, so you’ll have to adapt them a bit :slight_smile:
(Jay Pfaffman) #3
Also, you don’t need to install ruby. It is in the docker container.
