Display speed of the page of discourse is very slow
(ktt) #1
I have built an environment in reference to the following sites.
http://blog.discourse.org/2013/04/discourse-as-your-first-rails-app/
When I access to http://localhost:4000, until the page is displayed.
It takes about 1 hour.
Display of the page or faster How do I?
I’m using google translator because I can not use English :D
(Sam Saffron) #2
That vagrant image is a train wreck on windows try running discourse internal in the vm as opposed to off a share
(ktt) #3
vm you mean of Vmware?
(Sam Saffron) #4
I mean ANY virtualization solution. Vagrant sets up virtual box, that can work fine, provided the source code live in the vm. not in an smb share.
(Mittineague) #5
Same for me, the initial load is painfully slow.
I use Oracle VM VirtualBox
open GitHub
open Shell
start Vagrant
start Rails
open browser
go get a bite to eat and a cup of coffee
I’m wondering if throwing more memory at something might help or if I need to just accept that Windows isn’t the best OS for a *nix app.
(Sam Saffron) #6
Windows is fine, I use it and my dev speed is spectacular
The issue is having source code live in a Windows share as opposed to inside the vm
(Mittineague) #7
So instead of
C:/Vagrant
C:/GitHub (where the Discourse code is now)
C:/Program Files/Oracle/VirtualBox
I should put everything inside VirtualBox?
(Sam Saffron) #8
The source code for discourse must be inside virtualbox and anything used by discourse like gems. If you need a share, share in the reverse direction
