Displaying sub-categories in boxes
(Neil Lalonde) #22
@Trash No. :blush: I’m going to look at it now, and add the colour to the “boxes” style too.
(Neil Lalonde) #23
The two box styles should be more consistent now, with colours and same title style.
(Pad Pors) #24
Awesome feature :smiley: thanks.
a simple issue which is is customizable via admin panel also:
for the ltr languages, the color badge of the subcategory is in the left while it’d be nicer in the right:
in the category page the color badge is correctly in the right side of the category box, and this can follow the same rule.
(Neil Lalonde) #25
@Pad_Pors I fixed that today, so it will work by default without customizations. Thanks for reporting it.
(Alex Armstrong) #26
There’s a visual bug if you include an @mention in the description:
That should have read:
Discussions of the E-Resources Committee (@eresources-cmte).
(Neil Lalonde) #27
@alehandrof Is it something in your custom theme? I can get word-wrapping mentions in the description without a problem.
(Alex Armstrong) #28
I do have some custom CSS, but I removed it and I still get the same visual bug. I’m on v1.8.0.beta11, however.
(Jeff Atwood) #29
Time to
(Alex Armstrong) #30
Will do and report back. I managed to break my dev instance in the process and have to fix it first :slight_smile:
(mattdamod) #31
Hi @Trash :slight_smile:
I’m strugglingh to get my existing images to render the full width (see pic). Do I need to resize the pictures? If so, what is the potimal size?
Thanks
(Neil Lalonde) #32
@mattdamod The images have a max height of 40px, so the width will be changed to keep the same aspect ratio. You can add some custom css for .category-boxes .category-box .logo to change the size however you need to.
(mattdamod) #33
This has helped! Excellent! Thank you :slight_smile:
How do I get the mobile version to ignore these changes though? The mobile site looks awful now lol :slight_smile:
(Daniela) #34
Add your new CSS only on the Desktop tab (not in Common or in Mobile)
(mattdamod) #35
Thanks, @Trash. No such luck I’m afraid. I have entered only in Desktop. Is there something in this code that could be overriding it do you think?
(Neil Lalonde) #36
To target desktop only, add .desktop-view to the start of your css selector.
(Fer Nando) #37
Can i put boxes for category index wich any hack? For all main categorys, not only sub
(Neil Lalonde) #38
No, there’s no way to easily display the /categories page with the box style.
(Alex Armstrong) #41
Hey Neil. I updated my development copy of Discourse (after some hiccups) to v1.9.0.beta2, but I’m still seeing this:
My update script is this:
git pull
bundle install
bundle exec rake db:migrate
(It’s for my Vagrant copy.)
What else can I try?
(cpradio) #42
That looks like a customize CSS issue around mentions. Can you supply us with the relevant CSS?
(Alex Armstrong) #43
I don’t think so. Here’s the same issue with a new blank theme (and therefore no customizations):
