Distance post theme
(lucky) #1
What to do with the distance? (
(Mittineague) #2
I have not seen mention of the distance post theme here at meta, so I don’t know where you got it from. But judging by the image you posted and the theme’s name I guess maybe that’s how it’s supposed to be?
(lucky) #3
Maybe I said wrong, I apologize for my language, I’m from Russia, the problem is that the distance from the buttons to the end of the post is too big
(Mittineague) #4
Ah, OK, thanks for clarifying.
I don’t know what theme that is, the avatar is square and much larger than is typical. You should likely bring this to the theme authors attention as this could be a bug. If it isn’t a bug and is intentional. that leaves you the option of finding and using a different theme, or applying your own CSS to override what you don’t like about the theme’s style. The first thing I would do is get the avatar back to a sane size since that looks to be what is responsible for the problem.
