DNS problem with nameservers Digital Ocean
#1
My domain is regged with Godaddy and the hosting is with Digital Ocean.
Do I set the nameservers on Godaddy and in the networking tab on Digital Ocean?
(Gerhard Schlager) #2
If you want to use GoDaddy’s nameservers just add an A record that points to your droplet’s IP address.
https://godaddy.com/help/add-an-a-record-19238
If you want to use DigitalOcean’s nameservers you’ll need to update the nameservers at GoDaddy so that they point to DigitalOcean. This should help:
Afterwards you can use DigitalOcean’s web interface (Networking tab) to create your DNS records.
