Do I need to manually pull hotlinked images?
(Channing Hinton) #1
As I’ve stated in this post here PullHotlinkedImages triggers a “Job exception: failed to allocate memory” error, I’m currently getting out of memory errors when Discourse tries to download remote attachments. Once I have this issue fixed, will Discourse go ahead and pull any remote attachments that it contains? Is there a need to force a pull of remote attachments once the problem is fixed?
(Khoa Nguyen) #2
You can run rebake all of your posts with rake task
(Channing Hinton) #3
How exactly do I do that?
(Dean Taylor) #4
Seems you haven’t got that many posts - you can rebake an individual post from the wrench menu:
(Channing Hinton) #5
There are around 500 historical posts amongst about 180 topics that will be added in. What terminal commands do I run to do this en masse?
(Dean Taylor) #6
Off the top of my head I think it’s this:
cd /var/discourse
./launcher enter app
rake posts:rebake
You can check /sidekiq on your install to see how the baking :bread: is going.
EDIT: Yay, confirmation here:
Images no longer getting lightboxed part 3
(Channing Hinton) #7
Awesome and thank you.
