Docker configuration
(qwerty) #1
Hi can someone provide information regards to using docker image -GitHub - discourse/discourse: A platform for community discussion. Free, open, simple.
and how to configure image using environment variables.
(Erlend Sogge Heggen) #2
There’s documentation on the docker image repo:
(qwerty) #3
Hi, yeah i’ve read that as well, im asking specificly for environment variable configuration (if this is possible), as it seems there is a bootstrapping process for getting this up and running.
I should be able to :slight_smile:
1-pull docker image
2-set env variables for smtp.,DB configuratino
3-launch
(Felix Freiberger) #4
No, that’s not how it works with Discourse right now (although it’s being discussed).
For now, the official instructions are the only supported ones.
(qwerty) #5
Hi,
Thanks for the feedback, ok in this case is there a non-docker install method for this?
(Erlend Sogge Heggen) #6
No, Docker is our only recommended method of installation.
