Docker error on Bootstrap
(Sam Saffron) #21
FYI I added tests to launcher to avoid this issue in future
https://github.com/discourse/discourse_docker/commit/a3e18d952f053bc88b852422cad79eebdcb2d483
GOD MY AVATAR IS BIG ^^^ VERY SCARY
(D Iff) #23
When I run the below command:
root@MyUbuntu:/var/docker# ./launcher bootstrap app
it starts _pulling fs layer _:
WARNING: No swap limit support
Unable to find image 'samsaffron/discourse:0.1.2' locally
Pulling repository samsaffron/discourse
9dfbb44c55ff: Error pulling image (0.1.2) from samsaffron/discourse, read tcp 198.41.190.230:443: connection reset by peer
8dbd9e392a96: Download complete
21a54dd8e905: Download complete
535e9f84ec37: Downloading [=>               ] 4.227 MB/184.3 MB 1h24m20s
But it is cut:
535e9f84ec37: Error downloading dependent layers
2014/03/24 18:59:28 Could not find repository on any of the indexed registries.
Your Docker installation is not working correctly
See: https://meta.discourse.org/t/docker-error-on-bootstrap/13657/18?u=sam
And cgroup-lite is installed:
diff@MyUbuntu:~$ sudo apt-get install cgroup-lite
cgroup-lite is already the newest version.
cgroup-lite set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
My machine: Ubuntu 64bit 13.10 Sausy
root@MyUbuntu:/var/docker# docker -v
Docker version 0.9.0, build 2b3fdf2
(Kane York) #24
When you get a downloading error, walk over to your kitchen, and look at the microwave, and set a timer for one hour. When it goes off, try to bootstrap again.
The solution is literally to try again later.
(D Iff) #25
lol
Many times I have repeated it at long distances between efforts during a full day.
(Will) #26
docker:/var/docker$ ./launcher bootstrap app
9dfbb44c55ff: Download complete
535e9f84ec37: Download complete
2a584b2975bb: Download complete
2014/03/30 22:48:29 no such file or directory
root:/var/docker# ./launcher bootstrap app
2014/03/30 22:50:28 no such file or directory
root:/var/docker# cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=12.04
root:/var/docker# docker -v
Docker version 0.9.1, build 3600720
root:/var/docker# apt-get install cgroup-lite
Reading package lists... Done
Building dependency tree
Reading state information... Done
0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
Any ideas regarding which file it can’t find?
EDIT: I tried running the bootstrap as root, but that did not help.
root:/var/docker# docker images
REPOSITORY             TAG                 IMAGE ID            CREATED             VIRTUAL SIZE
samsaffron/discourse   0.1.2               9dfbb44c55ff        2 weeks ago         1.028 GB
root:/var/docker# docker rmi 9dfbb44c55ff
Untagged: samsaffron/discourse:0.1.2
Deleted: 9dfbb44c55ffbd5c1ca2b2f18fa17e0c420d9ebded963a41cf336bedac18c7d8
Deleted: 2a584b2975bbbbc0e8157c50117942ef540af5bb4a9c699fc8acef96c0789ae1
Deleted: 535e9f84ec37f029f12abf94073c813477701932fc11cf270ab46c9293a2137b
Deleted: 21a54dd8e905e6ee5d38c6d0d4c2e24cccf4eec46c24d9a39a47ec10964bf6f7
Deleted: 8dbd9e392a964056420e5d58ca5cc376ef18e2de93b5cc90e868a1bbc8318c1c
2014/03/30 23:21:07 no such file or directory
Edit 2: It appears to be this command that it’s failing on in the launcher
docker run -i --rm -a stdin -a stdout -a stderr samsaffron/discourse:0.1.2 echo working
2014/03/31 20:06:53 no such file or directory.
Edit 3: I don’t know what I did, but I fixed it. It may have had something to do with installing the lxc package (which apparently is not a dependency of lxc-docker) and rebooting.
(D Iff) #27
@Sapid
Did you solve it?
(Will) #28
Yes. As I recall, something went wrong during the docker installation. I had to fiddle with something, though unfortunately I don’t recall what.
This thread can be closed.
(Kane York) #29
Except for the part where you didn’t start it :wink:
And you should’ve had your own thread from the beginning.
(Will) #30
Well, the OP’s problem was solved, but now that you mention it, this is the thread that the error pointed me at, so I suppose it should remain open in case someone else gets directed here.
(D Iff) #31
Does this help you to help me: 301 Moved Permanently
And $ cat /etc/lsb-release:
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=13.10
$ docker -v
$ docker rmi 9dfbb44c55ff
Error: No such image: 9dfbb44c55ff
2014/04/16 20:39:10 Error: failed to remove one or more images
#32
Hi! I think this topic is old, but the URL is mentioned in the error, so I guess is correct to ask here.
I’m getting this error after trying to bootstrap the app.
exec format error
Error response from daemon: Cannot start container b635f92009aac24ae805fe829de3001849f768d000f890b8ea112d2004f4b376
: [8] System error: exec format error
See: Docker error on Bootstrap
This is my docker info:
Containers: 0
Images: 6
Storage Driver: aufs
 Root Dir: /var/lib/docker/aufs
 Backing Filesystem: extfs
 Dirs: 6
 Dirperm1 Supported: true
Execution Driver: native-0.2
Logging Driver: json-file
Kernel Version: 4.1.6-250
Operating System: Ubuntu 15.04
CPUs: 4
Total Memory: 1.975 GiB
Labels:
 provider=scaleway
I’m using https://www.scaleway.com/ hosting services (armv7 servers). Any idea what could be wrong?
Tks
P.S: Found more informationhere Discourse InstantApp - Feedback - Online Scaleway - Community :sunny:
(Kane York) #33
Well, I don’t think anyone’s tried to use Discourse on an ARM server yet, so we’re shipping binaries that are x86_64 only somewhere.
(Sébastien Santoro) #34
/var/discourse ] ./launcher rebuild app
WARNING: We are about to start downloading the Discourse base image
This process may take anywhere between a few minutes to an hour, depending on your network speed
Please be patient
Unable to find image ‘samsaffron/discourse:1.0.14’ locally
Trying to pull repository docker.io/samsaffron/discourse … not found
Tag 1.0.14 not found in repository docker.io/samsaffron/discourse
Version 1.0.14 hasn’t been published at https://hub.docker.com/r/samsaffron/discourse/tags/ yet.
(Sam Saffron) #35
It’s actually discourse/discourse:1.0.14 now… there is now SamSaffron/discourse anymore in discourse_docker/launcher at master · discourse/discourse_docker · GitHub
Not sure where you are getting that tag from…
(‫دبیرستان دانشگاه صنعتی شریف (‪Sanati Sharif‬‏)‬‎) #36
Hi, please help us, we have this error: :sadpanda:
root@irns1:/home/discourse# ./launcher bootstrap app
Please be patient
Unable to find image ‘discourse/discourse:1.0.15’ locally
Pulling repository docker.io/discourse/discourse
Error: Status 403 trying to pull repository discourse/discourse:
403 Forbidden
Since Docker is a US company, we must comply with us export control regulations. In an effort to comply with these, we now block all IP addresses that are located in Cuba, Iran, North Korea, Sudan, and Syria. If you are not in one of these countries and are blocked, please reach out to https://support.docker.com
(Rafael dos Santos Silva) #37
Can you access Docker site easily?
Does curl -IL https://hub.docker.com/r/discourse/discourse/ returns 200?
(‫دبیرستان دانشگاه صنعتی شریف (‪Sanati Sharif‬‏)‬‎) #38
NO, return 403 :
HTTP/1.0 403 Forbidden
Cache-Control: no-cache
Connection: close
Content-Type: text/html
(Rafael dos Santos Silva) #39
Where the server is located? What’s the ip?
Due to trade restrictions you aren’t allowed to use docker, but of you can rent a server elsewhere that would work.
Plus, if you really need to install on this server you will need to go the manual route (docker less).
It isn’t that hard if you know some Linux fu and Ruby fu.
(‫دبیرستان دانشگاه صنعتی شریف (‪Sanati Sharif‬‏)‬‎) #40
server located in IRan,[quote=“Falco, post:39, topic:13657”]
[/quote]
can you give some code snipe ?
If you have time, I am grateful to see the sample code here.
I know Linux, but I am not familiar with Ruby :frowning:
Thank you very much
(Mark Stanley) #41
Boo, getting error on ./launcher bootstrap app:
docker: Error response from daemon: Cannot start container 14c5594d838280282a9aaa70c671e139af42fe86ef2fd83ddfd045d42c04ee5f: [9] System error: write /sys/fs/cgroup/cpuset/docker/14c5594d838280282a9aaa70c671e139af42fe86ef2fd83ddfd045d42c04ee5f/cgroup.procs: invalid argument.
Any ideas? I’m using Docker v 1.10 and Ubuntu 14.04. All was going so smoothly…
