Does rebuild time scale with forum size?
(Jose C Gomez) #1
I’ve noticed that over time running the rebuild command takes longer and longer, most of that time is spent doing things like this
Can someone clarify what this is doing and if it is normal for rebuild to increase in time as the relative size of the forums (posts and such) increases?
Disable some user interface language options
(Eli the Bearded) #2
The Brotli compression is normal, but it shouldn’t scale with post size, just scale with fixed asset size. (“Fixed” assets being stuff that changes only on software updates, not with forum use.)
